Does anyone make a better speaker that'll fit in the factory hole on my '13 Streetglide? Seems a little hard to hear on windy days and when you go a little above half volume it doesn't seem to increase the volume level any.
Just about everybody makes a better speaker. It depends on how much you want to spend. Any 5 1/4 speaker will fit. Any bigger and you will need adapter rings.
UltraNutz has a recommended quality sound build:
Polk audio mm651 6.5" speakers
Soundstream pn 4.540 amp
Poly fill (to wrap the speakers
Adapter rings
All for slightly over 3 hundo. I ordered everything from amazon but the speaker adapters. Do a search on UltraNutz to find all you want on the subject.
Yes! If ya don't want to add an amp too, get a set of 6.5" 2ohm coax speakers ya like. Polk/infinity/jbl make some good ones. Mount them with some adapter rings from arc/dragonfly/throttleup... Enjoy!
