Audio Install Question for UltraNutZ
Ultra does it matter if the wire harness rest on or against the amp. Should i be concerned about some heat effecting the wires. the attached pic shows what I'm talking about. I did wiggle a little more slack but theres not much left. This pic does not show the final resting spot but you get the idea.
Ultra, On the high input wires the diagram you have in your drop box shows the color of the wires in a different order than what i have . My plugs go from left to right . black, brown red orange, yellow. and both right and left run the same way is your diagram flipped for the right side input, which would be left side of diagram. i think i confused myself thanks in advance.
you know.. someone else mentioned that as well a couple of days ago to me. My high input plug colors match the diagram i drew out.. What I did notice on mine also was if you look at the manual's diagram and then look at the diagram on the side of the amp, they were different. Had to call SS for clarification. Did they fix that in the newer releases of the manual? What's on the amp is correct so my drawing might be a little off based on my plugs. Can you take a pic of the high inputs and where they plug in on the amp for me and post?
ok yeah I see what they did. My wiring harness colors are layed out differently than your's are. Your's are correct mine were not.
So in this case, here is the correct diagram..
https://www.dropbox.com/s/ucnuf9hh3b...HD%20Radio.JPG
