Bagger Nation System for my Ultra Limited
Old 11-04-2012, 08:54 AM
GAZippoman's Avatar
GAZippoman
GAZippoman is offline
I'm finally going to do a little work to my '10 FLHTK to help the sound. Right now just have the hogtunes 5.25 speakers in the fairing.
I bought the dragonfly speaker adapters while I was at Thunderbeach. I have a set of 6.5" Infinity Reference 6032cfs I was going to put in the fairing and must move the hogtune 5.25's to the rear pods.
I'd like to power both sets of speakers, but at 2ohms, it looks like the only way I could do that is to run 2 PBR300X2 amps, one for the front and one for the rears.
I'll either have to remove the CB module (which I've never used in 50,000 miles) or move it under the head unit, or get one of the dummy module brackets to get a flat surface.
Even if I do that, will 2 PBR300X's fit? Or am I making too much work for myself and should I just get a PBR300X4 and replace all the speakers with 4 ohms? Although I like the idea of 150 watts at 2 ohms of pretty clean sound to all 4 speakers rather than 74 watts at 4 ohms.
Old 11-04-2012, 09:14 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
2 of the pbr300x2s will not fit inside the fairing. What you could do is setup it up with one of the Alpine KTP445U 4 channel amps which is good to go at 2 ohms. and they're great amps. I moved my CB and iPod modules below the radio. I haven't tried it but I would lay odds that the Alpine amp will fit with the CB module sitting on top of the radio as it is.
Old 11-04-2012, 09:36 AM
GAZippoman's Avatar
GAZippoman
I gotcha. But my understanding is that the alpine is only 45 watts per channel. That doesn't seem like a big increase over the 20 watts the head unit puts out.
Old 11-04-2012, 09:39 AM
UltraNutZ's Avatar
UltraNutZ
Tremendous difference over stock
Old 11-04-2012, 09:45 AM
GAZippoman's Avatar
GAZippoman
True, but if I'm going to do all the work of taking off the fairing, pulling off the tank etc, I'd rather put in the best quality I can. Guess I'll have to find a place to put another PBR300X2 at a later time....
Old 11-04-2012, 12:59 PM
UltraNutZ's Avatar
UltraNutZ
i agree. I just thought about something. You say you haven't used the CB module so here's an idea by removing the CB module altogether. check out the crude drawing. This way you can mount both amps inside the fairing. 1 on top of the radio, the other below the radio just make sure to leave that air gap of at least 1/2" both on top and bottom of the radio.
Attached Thumbnails Bagger Nation System for my Ultra Limited-dual-amp-mounting.jpg
Old 11-08-2012, 10:47 PM
waybo418's Avatar
waybo418
waybo418 is offline
Stupid question. How exactly did you do that? I'm thinking about getting the PBR300x2 and was wondering where I was gonna put it. I, too, have the CB and and HDPDPLUS and I would like to keep them both. Thanks!
Old 11-09-2012, 07:54 AM
UltraNutZ's Avatar
UltraNutZ
cantact Scott Ezzell @ ezzell141@comcast.net
he made a bracket that relocates the CB and iPod interface under the headunit and allows the amp to be installed on top of the headunit.
Old 11-09-2012, 07:58 AM
UltraNutZ's Avatar
UltraNutZ
If I hadn't already had the relocation bracket from a previous J&M amp I would have simply used industrial strength velcro (hook and loop) to mount the ipod module and cb module under the headunit and zip tied them for security.
Old 11-09-2012, 08:16 AM
WestTexasRanger's Avatar
WestTexasRanger
WestTexasRanger is offline
Still can't believe i posted that.. I must have been drinking or sleepy!
Maybe you were drinking in your sleep.
sprint07
Audio Systems
04-02-2016 09:45 AM
rrcrum
Audio Systems
02-08-2013 10:46 AM
lhgdale
10-31-2012 11:53 AM
fxdwg_rugby
03-16-2012 10:04 AM
c50plus
10-03-2011 03:59 PM
Quick Reply: Bagger Nation System for my Ultra Limited
