aux fun cable
aux fun cable
i currently run a aux cable from garmin to aux inlet on cd/radio unit...
problem i have is...the end of the aux cable that fits into cd/radio has come off...and its stuck inside the cd/radio unit....cant get a hold of it to pull it out...and replace with new cable
anyone ever had this or heard of anyone with this same problem
or any tips ideas
thanks
sniper for removing
or any tips ideas
thanks
sniper for removing
get yourself one of those long cotton swabs with the wooden handle that looks like this . put a dab of crazy glue on the end of it, slide it right in there and butt it against the broken plug. hold onto it for a minute or so and you should be able to pull it right out once they bond. don't use too much glue otherwise you'll glue the stick to the inside of the headphone outlet..
