Pre amp out
there are many adapters out there that work really well. It wires into the speaker wires from the radio, turns that signal into low-level RCA outputs.
here's 1 link
http://compare.ebay.com/like/3604305...Types&var=sbar
here's 1 link
We can do that for you.
The audio circuit after the D to A converters need to be modified prior to adding the RCA cables.
Line conditioners work ok, but still cannot address the fact that your manipulating the audio signal too much. That usually results in noise being left on the audio.Cheaper and faster option, but you get what you pay for.
Hoyt 1911A1
Audio Systems
03-03-2018 06:37 PM
