Advise on new audio
Timn, I went with the Sony mex3700, and used a biketronics adapter, one of the things you need to look for is 2 ohm speakers which come standard with HD, to 4ohm, this can cause issues, and if you add an amp this really plays into the setup.
My Sony has a USB plug, where I can put up to as many songs as a memory stick will hold. Now there up to a 32 gig, and you can put many songs in that amount of memory.
No need for an I-pod hookup, that memory stick works wonders, your switch on the right side of the handlebars change the channels, or songs what ever you desire.
There is a Blue-tooth, if you have a helmet Blue tooth.
Also has a telephone answer system in the radio too.
I haven't used that option, because I don't have the Blue-tooth in my helmet.
$130 for the radio, I believe it's around $170 for the Biketronics setup.
