sound dissappears?
Old 07-29-2011 | 09:12 AM
paul d's Avatar
paul d
Default sound dissappears?
Can you guys help me out? I have an 07 ultra and in the past week the sound from the speakers just stops. If i flick the switch to change from front to rear speakers the sound comes back on. but it will only stay on for a little while and I have to do the same thing all over again. any idea's. Thanks, Paul D.
Old 07-29-2011 | 11:47 AM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
not an uncommon post
give Iron Cross Audio a call, they should be able to guide you.
Old 07-30-2011 | 10:22 AM
Chasenfish's Avatar
Chasenfish
Check to make sure your CB isn't turned on, or if it is and you want it on, that the squelch is sufficiently turned up. The radio or CD audio will cut out when the CB overrides it.
Old 08-10-2011 | 08:23 PM
UltraTech's Avatar
UltraTech
its a common problem.
if you have the extended warranty, its covered, i just picked up mine today,
(my dealer let me take it out, drop it off and they swapped it) my scoot is my main transportation and i couldnt lay it up, so i took it out, they sent it out, and now i have to put it back in tommorow.
but the problem is not going away, its an internal problem and hd is well aware of it
Old 08-11-2011 | 03:42 PM
Harleypingman's Avatar
Harleypingman
The problem is sometimes caused by excessive vibration caused by one or more broken vertical fairing brackets and/or the riser bolts hitting the bottom of the radio's chassis. In addition to having the radio fixed, check those brackets and see if there is evidence on the bottom of the radio that it's hitting the riser bolts.
Carl
07JakeelwoodHD
07-10-2022 05:14 PM
shortride
Audio Systems
09-13-2011 11:37 AM
shortride
05-01-2011 11:38 PM
fire33
06-14-2010 06:00 PM
hazer
08-02-2009 05:17 AM
Quick Reply: sound dissappears?
