Adding a bit of bass question
I'm running an aftermarket fairing on my Dyna and I'm pretty happy with my system but am looking for a little more bass.
Fairing: http://recklessmotorcycles.com/index...uct_detail&p=8 I'm running the 4x5" speaker model
Head Unit: Fusion MS-IP500
Here's the manual http://www.jgtech.com/pdf/MS-CD500_M..._manual_V5.pdf
Speakers: http://dcgold.com/products/classic-line/n4c/ I'm only running two
I'm looking at adding these to give me more bass WITHOUT adding and amp: https://www.madisound.com/store/prod...oducts_id=8599
I'm also looking to do this on the super cheap, hence not adding the amp and better speakers. I plan on adding the woofers (cheap speakers) to Zone 2. The output on the HU is 70w per channel. Through the HU I can link Zones 1 and 2 together for volume control. I can also adjust max volume per zone as well as HPF an LPF frequencies.
My plan is to dedicate Zone 2 to the 5" woofers and adjust Max Volume, HPF and LPF accordingly to give me a bit more bass.
Finally my question, does this sound like it would work?
Jim
