CB Module Testing.....
I have the Boom Audio Music & Intercom (BAMI) kit, 77108-09, with the CB module installed on my bike and used the NUOH, 70169-06, per the instructions. Everything works as intended.
I'm not sure what you have done when you say you "integrated" the NUOH.
With the BAMI kit on my bike, the NUOH has two "in-put" connections (one for the 35 wire connector on the back of the HK radio, and the other "out-put" (labeled "interconnect" which connects to the bike's 6B connector. The BAMI kit (rider headset, passenger controls, etc.) and the CB module connect to the designated connectors on the NUOH.
The HK recognizes the presence of the CB via the CAN + and - wires to the pinouts of the radio; and, the CB gets its power and ground via the 6B connector/"interconnect" connection.
If you haven't connected the "interconnect" connector to the 6B connector, your CB module won't have power and the HK headunit won't know it's there.
If you have the NUOH properly connected at the back of the HK and 6B connector, the module may be bad. In that case, contact Clay's Radio (just google the name) as they're very knowledgeable about HD's CB. A simpler approach would be to have a dealer or a buddy plug your CB module into an '06 or newer Ultra.
Let us know what you have and what you find out.
If you have the BAMI kit, 77107-09, (the one for intercom only) and are adding the CB to it, let us know--there's quite a bit of difference in the wiring involved in adding CB if that's what you have on your bike.
Carl
Carl
What I did was took my Boom audio kit (intercom only) and using the schematic, integrated the NUOH into it. Interconnect included. Using my multimeter, power is going to the module. Radio does not recognize the CB. I get the "see dealer" prompt on the head unit. I will double check all pinouts again to make sure.
Adventurer
Audio Systems
02-09-2017 06:47 PM
