2015 Ultra 6.5 GTS Head Unit output voltage?
Old 09-29-2024 | 11:41 AM
Bookie's Avatar
Bookie
Default 2015 Ultra 6.5 GTS Head Unit output voltage?
I have a 2015 Ultra with a 6.5 GTS head unit which I am adding a amp to. I need the output voltage in order to set the gains on the amp. Can anyone help with that information?
Old 09-30-2024 | 11:46 AM
teedoff65's Avatar
teedoff65
If you have a DD-1 SMD, you can measure the exact volume level your head unit distorts at, Otherwise, a good rule of thumb is 3 bars from the top is safe enough to set gains.
There is a Setting Gains sticky you can follow.
Old 09-30-2024 | 03:57 PM
cshocker's Avatar
cshocker
You need the output voltage of the HU? That depends on what flash you have
Old 09-30-2024 | 04:10 PM
Bookie's Avatar
Bookie
How do I know which flash I have?
Old 09-30-2024 | 04:12 PM
cshocker's Avatar
cshocker
Have you had it flashed by a Techno Research dealer? Or is it factory?
Old 09-30-2024 | 04:14 PM
cshocker's Avatar
cshocker
Old 09-30-2024 | 04:17 PM
Bookie's Avatar
Bookie
it is stock, never been flashed since I have owned it.
Old 09-30-2024 | 04:21 PM
cshocker's Avatar
cshocker
Gotcha. Check those links I posted. You may have the "ultra flash" and not need a new one.
I'm also curious as to why you want to know HU output voltage?
Old 09-30-2024 | 04:23 PM
Bookie's Avatar
Bookie
I recently added a 520watt sound stream amp to the stock head unit and I need to adjust the gains so I keep from blowing speakers.
Old 09-30-2024 | 04:29 PM
cshocker's Avatar
cshocker
Gotcha. So you don't need the HU output voltage, you need output voltage from amp. As Teed suggested, check out the sticky page for setting gains.
Bookie
2014-2023 Touring Models
09-29-2024 11:34 AM
Fitterwelder
Milwaukee Eight (M8)
05-12-2019 12:23 PM
yooperhog
Audio Systems
46
02-20-2019 09:34 AM
rain rider
Audio Systems
06-27-2018 07:43 PM
joearizona
07-21-2008 06:00 PM
