Which Amp to which Speakers
Looking for feedback.
GTS head unit. 132_OFF.bin Techno Research flash.
HKI mini DSP.
Soundigital 800.4 EVO 4.0, SounDigital 400.4 EVOX, both are 4 ohms.
Fairing speakers: Ground Zero yellow baskets, 6.5 neo coaxial.
Tourpack speakers: Polk mm652 coaxial speakers.
Fairing lowers: Mmats PA601 mid bass.
How would you feed the speakers using the 2 amps I have?
Thanks.
HKI mini DSP.
Thanks.
HKI mini DSP.
Thanks.
HKI mini DSP.
Thanks.
Use the 800.4 for the Mmats and the Neo's, bridge the 400.4 for the GZ's - set your tune...should sound nice & loud.
JU2012FXDWG (08-27-2024)
I would run the Ground Zero's in the fairing, mmats in the lowers, and the Hertz Neo's in the TP. Sell the polks as they can't handle more than 150w and useless in the TP.
Can you recommend a video, forum post or article that will help me tune the set up I have with the HKI mini DSP?
Appreciate all your help.
I haven't run a DSP, but I have watched a few videos of the HKI and it seems easy enough to tune. You'll need a RTA and pink noise.
https://youtu.be/Qkll1miObts?si=Kus0Q9SUkGXsi3sV
