GZ coax wtf is this from????
so I've had an eventful few days with my system, first my music would randomly sound like garbage, then be fine, I thought it was my Stinger amp, so while investigating and verifying the gains were set properly, the Stinger sent up the smoke signal of death, I bought a Sound Digital 800.4 to replace it, got it setup and bridged at 180w or so to the GZ's while it sounded better, still didn't sound great.
Not sure how I missed it, but this is the right side GZ, I seem to remember someone else having this issue, @golfblues if I'm not mistaken, wtf is this from? I never over drove them, tried them at 200w for all of 3 minutes as they sounded awful at that level, always had the high pass at 80-100
Looks like it was played wet or something. Between that and not know what was going on with the amp, could be blown. Id like to see pix under that and the spider. See if the spider is still connected to the basket. Ive had them (hertz) not fully glued to the basket from the factory. Easy fix if thats what happened
so I took a peak, all is solid on the underside of the speaker, the cones are weak where the wrinkles are, it's odd as hell, as you said, it's as if they are weather worn, but the bike never stays out in the elements, but has been ridden in rain several times, as well as normal washes, but I don't spray water directly on them. They were purchased in February 2021, so warranty isn't happening
they lived most of their life in my old Street Glide fairing, been in my Road Glide fairing since May, thanks for the input! either way they're toast, I really liked how they sounded, a local stereo shop has them in stock, I'll grab another pair Friday morning.
That's wild. I run mine at 200watts off a DD Audio D4.125 and no issues. Love the sound. Now, mine are in pods, not sure how old your Street Glide was and if they were in pods or not, but looks like they got too wet and were played loud. I also run a rain cape in my fairing to keep water off anything that may drip in on the amp and the rest. Easy enough fix to replace, but maybe look at some type of external speaker cover for rain applications. Might even hit the cone with a weather proofing spray but I hear pro's and cons with that.
scott_0 (08-31-2023)
Since then, I set all of them at 200-225w and crossed at 120hz. I use a CC1 to make sure the crossover is set correctly.
You mentioned something bout your Stinger "sent up the smoke signal of death". So the amp was bad? If it was, that could certainly send a shix signal to the speaker and blow them.
I had a set do the same thing. It was from too much power and crossed to low (my own fault).
I thought that as well, maybe the 200w I sent to them for those three minute test did them in, and I'm not sure what the deal with the amp was, but my music would sound awful randomly then be fine, so ultimately, I think the amp did them in. I will run the new ones at 180w max from my SD 800.4
One last thing, assuming you have radio flashed?
