Taming the highs on the 6.5 GZ Yellows
I'm still fighting with these things on my 19 SGS.
I have...
RF Flash
Stinger 700
Dayton 408 Dsp
250W to the Speakers
HPF at 100Hz BW
I added the dsp with the hopes of taming the harsh vocals. I ended up pulling out -8.5dB at 2k Hz which seemed to target this area and am still having issues. I've played with the Q and if I narrow it, the harshness starts to come back so i have it at 3. Dropping anything from 8k and up doesn't seems to do too much.
My main concern here is that it seems like I am pulling out alot just to get it tolerable. I don't remember it being this bad when I first installed the system without the dsp 2 months ago.
Could something be wrong here? Amp?
I did a voltage check on my gain settings and it was up a few volts from where set it. Should this have moved? I set it back to 31.6v and I have the same results
Any help is appreciated
I have...
RF Flash
Stinger 700
Dayton 408 Dsp
HPF at 100Hz BW
Circa58 (08-03-2023)
I can't comment on the DSP settings, but I can say that when I fed them 250ish watts, running a Kenwood kmr-m332bt HU, I couldn't tolerate the piercing highs until I cut back on the "mid" section of the freq (which helped significantly). I believe I dropped the mid from 0 to -6, which tammed most if not all of that piercing highs. I bumped the bass up to +1 and the trebel to +2. For some that may be a loss of certain freq required to enjoy the song, but for my ears & set up, it works!
Now with that said, after that drop in the mids, I reconnected my oscilloscope, and at the same max volume, the speaker was only showing 26v now (which means the speakers are only getting 175w). Must be due to the dialing back of the mid freq.
Here is where I am at right now. I did an RTA session to get a baseline and this was after riding/tuning. You can see from my freq numbers that I changed them all to focus on the problem areas to give me some more flexibility. I used the HP and LP to taper off the rest. I'm not sure if this is the correct way to go about doing this because it was the first time I'm tuning. But hopefully we can get some comments or this can help some others get started.
One thing that still puzzles me is that some can run the GZ's and say they sound awesome and warm and others get these crazy highs that are unbearable. There is no chance any of this could have been tuned out with just the HPF.
NOTE: My master volume is at 0dB. It was just showing -20 since I was not connected,
I have...
RF Flash
Stinger 700
Dayton 408 Dsp
HPF at 100Hz BW
I have...
RF Flash
Stinger 700
Dayton 408 Dsp
HPF at 100Hz BW
One thing to consider with any comparison between bike to bike, is the difference in the bikes
2013 and down no pods.....
2014 and up have speaker pods......
I have a 2012, and a 2005, both without pods.
I might be wrong, but I suspect their is a difference in tone, and difference in wattage required to get the same volume in my 2012 vs a newer bike with speaker pods.
I used the 1000Hz -5dB test tone and set the gain to 31.6v like the Sticky above says. I did this with the EQ in the DSP bypassed. Then I set my HPF afterwards. The amp was set to "All Pass or Full" since I'm using the DSP
