Seek/next switch not working
Seek/next switch quit working on my 17 SG. Has stock head unit and bike was (upgraded, ha) to boom 2 system when new. Was operational for the first year I had it. Not working now. In the wiring diagram I see the switch harness labeled as can high, can low, battery and ground. Would like to know what wires to test to see if the switch is working. Or is it a possible settings / software glitch?
It may be a setting, try this
Start by pressing HOME
Select TUNER
Select FM
Hit MENU in the upper right
Make sure the first option is TUNE (and not seek or presets)
For what is is worth, and may be known already if so sorry:
http://boombox.harley-davidson.com/p...iusxm%3Csup%3E®%3C/sup%3E_satellite_radiohttp://boombox.harley-davidson.com/premium.html#siriusxm%3Csup%3E®
is an online user friendly manual/tutorial that I found much easier than the book. It lets you go right to the section you are looking for.
Hope this helps.
Select TUNER
Select FM
Hope this helps.
Select TUNER
Select FM
Hope this helps.
Select TUNER
Select FM
Hope this helps.
Thank you.
TriGeezer (05-26-2023)
jrobinson424
10-25-2011 09:53 AM
