Connector for the antenna to the radio?
Do you know what they call the special Ant connector Harley uses? I can't just reconnect the antenna to this connector. I also bought I hidden antenna strictly for my bike but I won't fit this connection. I don't want to spend 70 plus dothers on an antenna from Harley because I really don't listen to the radio all that often. I would like to just lay it down between the frame and the gas tank. But once you unscrew it from the tour pack it doesn't fit into the connector.
In the other thread I responded to, I believe I linked the part you need.
Here is a different link to the same part that isn't via a foreign ebay site.
https://www.alibaba.com/product-deta...834982067.html
The adaptor that Harley uses (the cream colored one) is a FAKRA B male connector, you need the female version of this to adapt to another kind of connector.
Here are two link that shows how to ID the connector type.
https://www.delock.com/infothek/FAKR...kra_hsd_e.html
https://www.everythingrf.com/communi...akra-connector
