Rockford Fosgate makes some incredible drop in subs that can unplugged and be removed easily. They only fit standard hard bags. Hopefully they will make them for the Harley extended bags.
they work in extended bags as well as CVO locking bags
Stock bags?
If yes, you will need to reinforce, brace, seal and port them for subs?
I would suggest going with a mid-bass.
What amp?
Do you know if my current AMP( Hertz SP 4.900 ) would power some midbass 8” along with my fairing and lid speakers with just 1 Amp? Or anyone that confirm that.
Unfortunately no. You'll probably need at 300-400w per 8" midbass to get started.
The most you could get out of that Hertz amp with a set of 8ohm 8" midbass would be 250w per speaker.
