Need new speakers
Hi there, you may want to consider the Rockford Fosgate Power speakers for your Harley. They are known for their high-quality sound and compatibility with aftermarket amplifiers.
You can also check out the article for a comprehensive review of the best sound system options for your motorcycle: https://yourmotobro.com/best-sound-s...rley-davidson/
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
7 Best Harley Davidson Stereo Systems
- Rockford Fosgate TMS69BL14
- Kuryakyn 2720 MTX
- Boss Audio Systems MC470B
- Hogtunes 5.25″ Front Speakers
- Aquatic AV AQ-MP-5UBT-HS
- Rockford Fosgate HD9813RG-STAGE1
- Rockford Fosgate HD9813RK-STA
Groucho1 (02-09-2023)
I'm running a SounDigital EVOPS 800.4 to 6x9 Ground Zero Yellow Baskets in the lids, and 6.5" Yellow Baskets in the fairing. I've been very happy with the system. It's also been robust to high mileage, drastic temperature variations, and bad weather. I will say the magnets in the 6x9's are also large and heavy. If you're trying to avoid that, they may not be the speakers for you.
Hope this helps!
Hope this helps!
Circa58 (03-05-2023)
I think he is a shill, or a spammer. I have not figured it out yet, but all of his posts since he joined are "off" just enough that I am just waiting to see all the links to the other sites he shills for. This one may be the first.
Hope this helps!
Hope this helps!
UPDATE!!!! Replaced the fairing Neos with GZ yellows definitely more mid bass and they pound HARD!!! So new setup is…. Hertz SP 4.900 amp, GZ YELLOWS in the fairing and Hertz SX 690 Neo in the lids. This setup without a dsp is super loud clear and with some nice mid bass. Super happy with this setup 😎👍🏾
The following 2 users liked this post by Mac daddy 103:
NorthWestern (02-11-2023),
Red89gt (02-16-2023)
That setup is as good as it gets for a 4 speaker setup without a dsp. You will be able to drop the HPF a bit on the front now. I suggest the filters be set around 80-85 on the front and 70-75 on the rear. As long as you don't have the gains to high that should have damn good midbass.
This is not my settings, this a pic for reference but this is the amp I do have
