Looking to upgrade stock audio on 2016 Ultra Limited
Hey guys, I'm wanting to upgrade my stock setup this off season here up North and need some direction. I have a 2016 Ultra Limited with liquid cooled heads. I'm considering either a 4 speaker setup, 2 in fairing and 2 in the tour pack, or a 6 speaker setup, adding 2 in the lowers if possible. I also would like to keep the stock head unit but maybe there are better after market head units I can upgrade to. My budget is $2k but if I can save a few dollars for lunch with the wife that would be great. If the cost is more I'm willing to entertain that also.
I started to inquire about this back in 2017 to get some ideas, and guys here were throwing around Hertz, Arc Audio, AD Design, and several others. I started to read threads last night and after several hours and five years later I think some things have changed.
Any suggestions are appreciated and I'm still going to research and read to educate myself. Also, I will be doing the work myself.
Thanks in advance and ride safe!
The first thing you will need to do is flash the head unit. My suggestion is an 8/2 flash as it is the flattest. You will lose fade control, but you won't need it. As far as adding lowers, these will work and look stock.
As far as adding lowers goes, I suggest the hertz sx neos in them and the TP. the drop right in both locations without any mods and are waterproof. They also sound good. For the fairing, either GZ yellow baskets or mmats 601cx. The pods will need some mods to add those speakers, but it will be worth it. A sd 1200.4 4 ohm will power it all providing 200w each to the fairing and 150w to the lowers and TP running them paralleled. I also suggest the HKI mini dsp to tune it all so you can get the most out of your setup.
You will need these to convert the signal from the HU to dsp hookup.
Axxess AX-MLOC-HD1 2-Ch 80W Line Output Converter (parts-express.com)
I just got done with my install on my 2017 Ultra Limited. I went with the Hertz 2000W SP4.900 amp and 4 of the Hertz SX165NEO speakers.
I got my setup from Volunteer Audio.
Carlos over at NVS Audio is a fantastic source for info, but I would suggest looking at the videos from Jay over at volunteer Audio as well. ( You Tube )
Their systems are more "rider systems" and less of a competition system. (IMO)
My install was totally plug and play and I reused the factory GT radio. ( The kit I got comes with a tool to re-flash the factory radio. )
The sound quality and output is beyond amazing. You can hear it clear as a bell at any speed.
Ride safe!
polarisbob (10-27-2022)
