Amp wiring kit ?
Amp wiring kit ?
I was looking at the stinger svtk4681 wiring kit for my audio install. I will be running ground zero gzcf 6.5spl in the fairing and a euphoria fm100.4 to power them. Eventually I will add speakers in the lid.
is this kit worth the money or does anyone have experience with something else better ?
This -
Also if you are going to add lid speakers down the road I would look at a different amp. That one will worked bridged to those Ground Zero speakers, but once you get lid speakers you will need to add a second amp or get a different amp.
Maybe look at this -
Amp- stinger spx 700x4, Mmats pa601cx - fairing, Mmats pa 690cx - lids or
Amp- sd 1200.4 4, GZ yellow baskets - fairing, hertz sx 690 - lids
madhunter60 (08-24-2022)
Those Ground Zero speakers are 4 ohm speakers, so they would only get 100 Watts wired to their own channel or in parallel. Bridged you could give them 200W. The Amp Wiring kit that Madhunter is referring to is the one I listed in the Amazon link.
05-02-2023 03:40 AM
TXCHOP
07-05-2020 04:26 PM
