speakers upgrade (and amp ?) on OE head unit ?
If you wired both, left and right, together in parallel, yes, it would. If you wired lower and upper speakers in parallel (if you have lowers), then no it wouldn't.
I would seriously consider pausing a moment and budget a bit more money for a much better bang for your buck.
An SD 800.4 amp, or a stinger(will retain FM) and pair of mmats cx and a pair of mmats 690cx 6x9's would be a way better set up for not a lot more money. Just my thoughts. That way you're not wanting to replace stuff 3 months down the road cause they're not loud enough.
