Radio switched to weather, then display went off
We gave a 2016 Ultraclassic CVO. Riding along listening to the radio today and all the sudden it swapped to the weather channel or alert. It allowed me to swap to Bluetooth then the display went black. Now it just plays weather with no display. Nothing we do is allowing us to change any channels or get display back. Any ideas? Ive seen a fix for the weather part but the display turned off as well....
That is really strange. I had an issue recently where the head unit did not power up at all. It turned out to be the 20 amp fuse. In your case the weather playing shows it’s getting power. I would consider a full reset and see what happens. I’m not sure if or how to reset the head unit, but I would probably start by pulling the main 50 amp fuse and starting there. Make sure you follow the manual if doing that or your security siren will go crazy!
Good luck
Good luck
