Pbr 300x2 cutting out
Hi,
I have had a Pbr RF 300x2 amp on my bike since 2016 (15 flhxs) paired with infinity kappas and a magic box. I had it set for the longest time with gain at 8 -8 1/2, filter set to High pass and frequency **** in the middle ( not sure off hand have to pull the fairing cover to get the exact setting.) for the past two seasons it’s been cutting in and out at higher volume where it never did in the past. Tried re adjusting the gain and settings and its good for ride or two then does the same thing again cuts in and out ( no distortion). Is the amp going bad? Could it be something else? I also checked all connections to make sure there were no shorts, etc.
Anyone have that happen? Is the amp going bad ? Anything else I should check?
