EQ in Boom System?
EQ in Boom System?
Is there some kind of factory EQ on a 2020 FLHTK? I use mainly headset (High Quality) and run it through either carplay or just the AUX on the BOOM!. It is output though the 7-pin DIN connector to a 3.5MM headphone jack. But the sound is next to horrible, and no matter what EQ I change to on my phone it does not change what I hear coming out. Is there some kinda EQ that somehow is designed to protect the crappy speakers that I can disable? I can understand the MOCO trying to save the outside speakers, but on a headset, with outside speakers disabled, no excuse. I can listen directly through my phone or Ipod and no issue with the sound. Is this just me?
Rollbar (06-23-2022)
I Would imagine CVO flash is from Stealer, of course, but what about aftermarket flash, where does that come from?
Just bought the bike a month ago and been searching for information and first I have heard about the CVO flash.
Thanks,
Not sure what DSM was talking about “CVO flash”. Maybe he was drinking that night or something.
You are asking a unique question that probably won’t be answered.
When a radio is flashed (CVO, 8/2, RF, DD, Soundz, etc) it flattens the EQ and changes the output voltage. So it’s actually quieter than stock. But flashing is needed when adding aftermarket amp and speakers. I’m honestly not sure if a flash will change the wireless headset sound or not. You may have to take a gamble, spend some money and find out. TBH.
To get it flashed, you can’t just take it to Harley or a car audio shop. Most car audio shops don’t have the correct flashing tool. You’ll need to go on Techno Research website and find a dealer near you. It will most likely cost you $80-100 to try. It may work, or may not. Your choice if it’s worth the try.
Rollbar (06-24-2022)
First, if you have it flashed, you won’t be able to adjust the EQ. Only treble and bass.
