21 Road Glide options.
Good morning, I am getting ready to pull the trigger on some equipment. I am hoping someone can chime in with thoughts and/or suggestions.
As I have said in previous posts, I am looking for warmth above all. I am hoping that I can tune this proposed system low enough and with enough power to get both loud and warm music.
I am thinking the GZ yellow basket for the fairing.
I am thinking the Cicada CX65.4 speakers for the TP.
I am thinking (1) SD 800.4 for the GZ speakers. I plan on bridging this amp for the GZ speakers
I am thinking (1) SD 400..4 for the Cicada speakers. I plan on bridging this amp for the Cicada speakers
I am thinking a Dayton DSP with the bluetooth dongle.
Does this sound like a solid plan?
Would I be better off with one amp, perhaps a 1220.4?
My concern will be how easy is the DSP to use?
What would I need to do to bring the GZ speakers down to the 50HZ?
Where would I want to bring the Cicada speakers down to as a starting point.
Will I need anything to fit the amps and speakers under the fairing?
Any other suggested parts/wiring harnesses etc that I would need?
I am hoping to get my head unit flashed.
Thanks for any help,
Bob
Bob
Do you have RDRS? If so you'll need to remove the bracket and move it. You'll also need an amp rack.
I have a 1200 and a dayton and its a tight fit even with the amp rack. I wound up using velcro and zip ties for the RDRS module under the HU and then the amp and dayton on the rack.
There is a bit of a learning curve with DSP's. Setting gains correctly though in the most important thing, so you're not blowing stuff up. There is a guy here in NC that offers remote tuning, if its too overwhelming to tackle yourself.
And you DEF need your HU flashed.
Don't forget, unless you're blasting your speakers at full volume constantly, you're not even hitting your full target wattage very much.
Are you talking about that big white module on the left (clutch) side by the HU? If so, that's the HD Connect module our 2020's have.
It was a grand idea HD had...kinda like OnStar. It didn't last long and they abandoned it quickly. Pretty sure 2021 + models didn't have it.
I had to remove that bracket and then also find a new place to stick that HD Connect module. I'd like to just remove it but I think it throws error codes then.
If the OP has RDRS, I just didn't want him concerned and looking for something that is not there. Again, I could very well be wrong.
Correct me if I'm wrong (and I quite possibly may be), but I don't think the RDRS unit is up front under the fairing.
"Harley-Davidson motorcycles equipped with H-D Connect service include a cellular telematics control unit (TCU) that functions as a (LTE) enabled modem connecting equipped motorcycles to the cloud"
I found this out when I was adding a CB to my bike. Originally HD said CB will not work on my 2020 even though wiring/antenna was there? Realized the only reason was that the TCU was mounted where the CB usually mounts.
I just mounted the CB on the other side where the WHIM would normally mount. Now that HD has abandoned HD-Connect...magically the CB fits my 2020.
Don't want to de-rail the OP's thread but if you're talking about #31 in the pic below, that is the TCU for HD-Connect. Again, 2020 was the only year it's there as HD abandoned it quickly. Not there on 21+ models.
I'll confirm next service and if so I can get rid of that stupid thing! lol
