Anyone using Posi-Tite or Posi-Lock connectors?
Stinger SPX700X4 speaker output wiring w/Deutsche, Molex, or Packard Weatherpack?
I currently have the Stinger SPX700X4 and I am thinking about rewiring the speaker outputs using a 2 - 4 pin or 1 - 8 pin Deutsche, Molex, or Packard Weatherpack.
Is there any issue regarding volts or amps if I were to use one of them?
My current connectors are waterproof solderless butt connectors and currently there’s been no issues. If I want to swap my amp out this seems to be a much easier and cleaner solution.
Thoughts?
Thoughts?
Received 5,298 Likes
I don't use any type of connectors from the amp to the speaker, I leave it as one complete wire. I use wire ferrules on the end of the wire going into the amp and whatever connector matches the speaker terminals. I know folks like soldering the speaker wires to the speakers but I have never had issues with properly matched terminals. If I change speakers I just unplug the wires from the terminals and plug them up to the new speakers. I live in the country with some seriously bumpy roads and have never had any connection problems with this method.
On the few occasions when I have swapped amps the wire ferrules were in good enough shape to just put them into the new amps terminals and screw them down.
badazzpred (01-19-2022)
I agree with Hoyt. No splices if possible and I always leave a little slack so I can redo connections easily. I've never used Posi-Tite but they basically seem like an inline version of a Marrette. Never had an issue with any Marrette I've used but then again my household AC connections aren't subject to the same vibrations or environment of a Harley.
