2 Stinger amps
I have one tray now. Biketronics maybe? I was thinking 2 could fit side by side like I’ve seen with some of the other amp set ups. I’d hate to order it and send it back if it won’t work.
The amp rack with the lower plate would definitely let them fit. https://garagebaggerstereo.com/colle...and-up-batwing
Although, looking at the dimensions, it looks like the 2 may just clear.
Agreed. The wiring comes out on the long sides of those amps. But, I’m thinking if the non wire side of each is butter up against each other it might work. I have a flat piece of quarter inch aluminum in the garage that I can play with. And I suppose cut a couple pieces of wood amp size and play with it before before buying everything. I have a DSR1 tucked on the left side near the speaker in the BT bracket, so that shouldn’t be an issue.
I only have 4 speakers. One stinger 700 now. Was thinking I’d get a second so I could bridge them both. It’s not a pressing issue per say. If I can add a second easily enough, then I’d go that route. Otherwise will sell it to get an angrier 4 channel. 🤷🏻♂️
