Ground Zero GZCF 6.5 SPL: HOW much power?
Old 10-19-2021, 08:53 AM
Badbagger's Avatar
Badbagger
Badbagger is offline
Default Ground Zero GZCF 6.5 SPL: HOW much power?
For those of you running the Ground Zero GZCF 6.5 SPL's, what kind of amp are you running to them? I have watched the videos from Carlos and he runs these from 800.4's bridged and on the flip side, I have read others are very happy with running 2 sets, i.e one in the lowers and one in the fairing from a single 800.4. On a different note (no pun intended), are there still issues with SD amps and Ground Zero speakers cutting out at above half volume? IIRC Carlos has "cut the wire" as it were to fix the issue on the crossover but that effectively takes a 12db crossover and turns that into a 6.
Maybe the set in the fairing on a 400.4 bridged and the set in the lowers on an 800.4 bridged so I can pump up the juice if they can't be heard over the fairing speakers? I have a line on 400.4 and 800.4 Evo X factory refurbs and would like to order before stock runs out.
Thanks and peace out
Old 10-19-2021, 09:45 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Hoyt 1911A1 is offline
Never heard of this before. If it is "cutting out" it sounds to me like it is being overdriven and the amp is going into protection mode. I can crank my GZs almost to the top notch of my volume before my amp complains about the distortion with the 150 watts I am feeding them. I am using an Arc amp though, I don't know how an SD would handle that situation.
I'm just going on empirical data here, but if a bridged 800.4 can push a set of 6x9s that are BEHIND me loud enough for me to hear on the highway, I wonder if that kind of wattage might be overkill for a set of 6.5" speakers that are in front of me.
Old 10-19-2021, 12:58 PM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,535 Likes on 930 Posts
There are plenty reports on bad GZ 6.5 coax including the ones had... Right now I wouldn't go near them
Old 10-19-2021, 01:13 PM
Hoyt 1911A1
What have you been hearing about failures? Do you know how many watts were being fed to the ones that failed?
Old 10-19-2021, 01:55 PM
golfblues's Avatar
golfblues
Quality control has been terrible lately. Mine were setting off the fault in my arc moto 720 auto at 150 Watts. Also the paper cones started to disintegrate. Yeah I've since replaced them with arc CX6's and have had no problems Use the search feature here and you'll read many others having problems with GZ's. Even one resident expert and GZ fan here has joined the club of non believers... Mine were returned and I received full credit no questions asked... And that was from my dealer. I sent emails to GZ while I was having problems and did not get a response. Arc moto gave me the heads up on GZ tweeters sending faults to their amps
The following 2 users liked this post by golfblues:
boog7820051 (01-18-2022), Hoyt 1911A1 (10-19-2021)
Old 10-19-2021, 02:00 PM
Hoyt 1911A1
Quality control has been terrible lately. Mine were setting off the fault in my arc moto 720 auto at 150 Watts. Also the paper cones started to disintegrate. Yeah I've since replaced them with arc CX6's and have had no problems Use the search feature here and you'll read many others having problems with GZ's. Even one resident expert and GZ fan here has joined the club of non believers... Is mine were returned and I received full credit no questions asked... And that was from my dealer. I sent emails to GZ while I was having problems and did not get a response. Arc moto gave me the heads up on GZ tweeters sending faults to their amps
Good info to have. I wonder what a suitable replacement for the GZ would be? I got mine back in December and haven't had any trouble with them. They can really crank without distorting.
mrmagloo (10-19-2021)
Old 10-19-2021, 02:16 PM
cshocker's Avatar
cshocker
cshocker is offline
You got a good pair then!
I've installed 1 good pair. Another set looks like shix and are shot after getting 300w and crossed at 85 with DSP. Had another pair that would put amp into protect mode at about 150 watts. Just got a bike and one of the GZ in lowers is completely destroyed and they are running off of 2 channels of a JL MX500/4. They are just like their amps: some good, some bad.
Circa58 (10-19-2021)
Old 10-19-2021, 02:33 PM
golfblues's Avatar
golfblues
I replaced them with Arc CX6's....great choice
I think I'm the only one using them here but they are great
Old 10-19-2021, 02:39 PM
Fireball Jack's Avatar
Fireball Jack
Fireball Jack is online now
I am running mine off of a 1200.4 2 ohm @ 250 watts crossed @ about 90Hz. They get loud and thump a bit.
Old 10-19-2021, 04:51 PM
Badbagger's Avatar
Badbagger
Well hell, I need a couple of sets of reliable waterproof 6.5’s. Not worth flipping a coin.
Quick Reply: Ground Zero GZCF 6.5 SPL: HOW much power?
