Help with rk audio
Seems like it would make wiring easier if it was in the bag with the amp then? If you have your phone hooked to a charging cable will it still run the bluetooth properly? Sorry if this is a stupid question I have never used blutooth much. I was looking at the mtx controller with the handle bar mount, thinking that possibly i could mount it in the dash panel by the speedometer.
I used a charger all the time. I also picked up a couple media buttons, put one on the fuel tank, for volume and to skip songs. They worked okay. I added a Dayton dsp with Bluetooth later, and would stream music direct into that as well. They both worked great. The only issue I had, was leaving my WiFi on. While riding the phone would try to connect to different networks. Just an FYI, turn that off while riding...
