Error code cuz tour pack spkrs removed 2013 limited.
My Kenwood stereo gives me an error reading because I removed the tour pack with speakers. Is there a resistor or something I can hook onto the wires to fool it? I know I could jump with the wires under the fairing to the front speakers but I do not want to have to remove the fairing every time.Thank you
There are resistors you can buy to act as a dummy load. You could buy a connector that you'd plug into the wiring harness when removing the TP with resistors across the speaker outputs. Just make sure the resistor has the proper values for impedance (2, 4, or 8 ohms) and wattage to handle the output of the head unit or amp without burning up.
beardogg (06-27-2021)
