6 speaker CVO plan
Old 06-23-2021, 08:31 PM
Rcloud72's Avatar
Rcloud72
Rcloud72 is offline
Originally Posted by Atomic Bagger
Is this the plug to bypass the rear speaker amps, and wouldn't I need two?
the plug i have is for the boom amp in the fairing only. but yes if your cvo had two amps (one in fairing and one in the bags ) you’d need another plug for the bag amp. this plug has the rear outs on it though. i bought the AHB plug but i’d also bought a RF amplifier hook up kit with the amp rack and it came with the same plug so i ended up with two. i’ll find the link to it and post it for you
Old 06-23-2021, 08:39 PM
Rcloud72's Avatar
Rcloud72
Rcloud72 is offline
i can’t upload the link for some reason but it’s called “front factory amplifier bypass harness” on ahb website. it goes for 89$ i’ll sell this one for 40$ shipped to anywhere in the good ole U.SofA!!
Old 06-24-2021, 11:28 AM
Atomic Bagger's Avatar
Atomic Bagger
Atomic Bagger is offline
That's a great deal Rcloud and I'll keep it in mind as I gather the parts. Looks like I need a few more bypass plugs as I also have amps in both bags, so a kit with all of 'em may be the way to go.
Old 06-25-2021, 03:17 PM
Atomic Bagger
Originally Posted by SBates08
Pretty sure that bike has the 8/2 flash from the factory. Would have to check Bin file to be certain. 135_off.bin is the 8/2.
Can I check my HU for this .bin?
Old 06-26-2021, 10:06 AM
mcdc1224's Avatar
mcdc1224
mcdc1224 is offline
Hold the mute button while you power up, that will get up into the menu for the file on the GT's
Old 07-08-2021, 10:31 AM
Atomic Bagger
Originally Posted by mcdc1224
Good list. For the money, I might look at a 2400 instead of the 800 and the 1200. I ran that setup for a while, then switched the lids to Hertz. As far as flash, I use the 8/2 since using the DSR. The RF will have the fade, if that is important to you....
Couple of questions related to this suggestion.
Best way to hook up the 4-channel amp (to my 6 speakers) if I went with the 2400.4?
Would the 800.4 power the 4-GZCF's up front sufficiently, or do I really need a 1200 for them if I stay with the 2-amp system?
Also, I'm still confused on the need for using a DSP. I have some pretty significant high-end hearing loss, so will I gain any benefit by using it?
Thanks for any help.
Old 07-08-2021, 01:26 PM
mcdc1224's Avatar
mcdc1224
mcdc1224 is offline
Your original plan is a good one. Those GZ's will need more than the SD 800 can supply for 2 sets of them, in my opinion. The DSP will allow you to install without a line level, give you equalization, able to turn gains on channels up and down as needed, better control using HP/LP settings, separate channels for tuning etc......I would never leave home without one. I was adding a set of lowers and Shannon suggested the 2400, and glad I did. Made the install simpler, saved room and a little cheaper. Gave me a ton of options moving forward.
Old 02-19-2022, 10:07 PM
Atomic Bagger
OK, guys, time to hook all this crap up and tune it, so I need the next round of advice,
I ended up with:
2018 CVO Street Glide
Stock HU
DSR1
EVOX 1200.4 4 ohm for 4-GZCF Yellow Baskets (upper and lower fairing)
EVOX 800.4 4 ohm for 2-MMAT's 6x9 (saddlebags)
AGB cable assemblies for all of it
My questions at this point are regarding how to use the amps. I should have gotten a 2 ohm version of the 1200, but didn't. Do I just use all four channels straight up, or will I benefit from employing other methods of connection? And the 800 in the rear?
Thanks...again, and more to come.
Old 02-20-2022, 12:23 AM
Fireball Jack's Avatar
Fireball Jack
Fireball Jack is offline
I ended up with:
Stock HU
DSR1
I would do this
1200.4 straight up to the upper GZ's and the Mmats in the lids.
800.4 bridged to the lowers.
That will allow you to send more power to the lowers and blend the sound.
Old 02-20-2022, 09:02 AM
Atomic Bagger
I hadn't even considered that. Sounds reasonable, but the cable assemblies that I purchased connects the 800 (mounted in the saddlebag) to the lid speakers.
Quick Reply: 6 speaker CVO plan
