GTS CarPlay without headset
10-08-2021, 05:00 PM
Quote:
Originally Posted by
tunaman
So wire a toggle switch to those two pins instead of the jumper, and then you can toggle the connection off and on when you need.
I did this with a toggle switch and it works perfectly.
02-24-2022, 07:51 AM
have your bike paired to a second cheap headset or a use your sena headset turn it on and put it in the top box or phone usb pop hole on the dash?
02-25-2022, 04:30 PM
06-27-2022, 06:41 PM
Easy solution
mikes300
AH LOL i know nothing about a wired setup, its 2021!! LOL
PS i have a WHIM, it works flawless, its a25K bike spend the extra bucks and do it right lol
jumper on pins 4 and 1 backseat din plug fix the problem
01-06-2024, 01:14 PM
I just pulled the rear plug out of mine and you cut the thick black wire going into it. Strip that back and there is a red and black wire inside. Crimped those together and now have carplay working with nothing plugged in.
bmaier
05-28-2014 12:02 PM
Talldog
11-03-2013 05:41 PM
Adam.Moss
02-23-2012 02:29 AM
big_e78
03-22-2010 07:56 AM
ddwyer
06-10-2009 06:07 AM
