New Batwing Setup questions
The Stinger is fine. Or the SD800.4. Or....... As long as u can get 250-275 watts to them. If there is even a slight chance in hell that ur gonna add more speakers, get the amp u will grow into.
Do the Rockford or 8-2 flash. With the flash u will need a LOC like the SNI 15.
If u plan on bridging the amp and retain stereo, think ur way thru the RCA inputs into the amp as ur gonna need left and right separation from 1/2 and 3/4.
Other than that u should be good to go.
T
T
T
T
T
T
I just realized I got an sni 35. That being said, what’s a target output voltage to aim for coming out of this?
stinger amp and sni is on the box and bike is now torn down with the boom 2 removed. Speakers won’t arrive until Tuesday and that morning I get injections in my neck do not sure how I’ll feel after to finish the install. I plan on running the stinger bridged and def want stereo. It looks like the techno research tool will allow me to try different eq curves, so may just snag one because yeah, who knows it in a few years I may want to add lowers.
What I'm saying is, you can save the 250 bucks as youll.not really need to change the flash even when adding more speakers. But if you got the cash to spare a s just want to play around with it, then have at it.
teedoff65 (06-20-2021)
just so you know, having someone flash your radio should only cost about 50 bucks. Once flashed the only two you may ever want to try are the harley flash and the rf flash. Not sure if the techno tool ca do the rf flash.
