Should I amp upgrade or run a second.
What speakers are you running and what speakers are you planning to add. Can't be very loud running 6 speakers on one 4 channel amp. Or at least, you're not playing your speakers to their fullest.
I think two amps would be better if you continue to run 6 speakers, but again which speakers?
Right now i have BT7.1 pro's in the fairing, hetz sv 165's in the lowers and arc 602's in the TP, no idea on lid speakers yet if I go that route. It is loud but I know I am leaving a bunch on the table and since I have no gain adjustments right now I want to add the dsp to clean it up.
Interested in what you end up doing here as I was thinking of maybe dropping in a 2 channel amp for the rears, separating the 7.1 Pros and SV 165s on the 4180, and putting in a DSP. I also agree it's plenty loud enough and so far I'm not convinced that I'd gain enough to make it worthwhile. I've checked the gains and get plenty of volume with no clipping. I'm going to play with the HPF cutoff on the BT355s to see if I can get a bit more on the bottom end before doing anything.
Your situation in going to 8 speakers would be different. I know most would advise putting in a second amp for your rears/lids and I wouldn't argue that's a bad thing but you might want to run 4 ohm lids in parallel to your Tour-Pak pods first to see how that sounds from a volume perspective. (I'm pretty sure you'll find that's how your front 2 sets are wired). You could then drop in another amp and a DSP if the results weren't to your liking. Just a thought.
Nope you are correct and I am wrong they are in parallel, again know enough to be dangerous lol. I don't necessarily want to gain any volume but to clean the sound up, my understanding is that adding the dsp and another amp I can give each speaker it full potential and tune them for better quality. That said please correct me if I am wrong on anything I say or have said.
I think what I'm looking to gain besides sending each speaker enough power is to have each speaker get the correct EQ, I know my 7.1 and spl do not sound there best because of being in parallel. I just don't know enough and it has been long enough that tech has changed, so there could be a amazing 8 channel amp that solves everything for me.
