New audio set up killed Fm/Am
I’m sorry if this information is already in the forum …I have not been able to find it.
2017 road glide
i followed one of the popular audio set ups from this forum. (Some great advice here btw)
Stinger amp, BT line levelers, Mmats in the faring, RF Bag lid speakers.
My bike has the hidden antenna that is under the faring powered by 12 V.
With the new set up I get near zero radio reception. The majority of my music comes directly from my iPhone, however it would be nice to have some FM reception.
I used the same 12V ignition driven “spare” power wire inside the faring to power the blue enable or signal wire on the amp.
Is it the amplifier itself killing radio reception or is it simply the blue enable wire sharing the same power source as the antenna?
could I switch to a stubby fender mounted antenna and scrap the under faring antenna or is there a filter or another power source I should connect to?”
thanks in advance
EdD
2017 road glide
thanks in advance
EdD
2017 road glide
thanks in advance
EdD
2017 road glide
thanks in advance
EdD
I don't think the Stinger is your issue, but your antenna. Heck, before I had an amp in the mix, I tried a hidden antenna on the stock system and FM reception went way down.
The hidden antenna is the problem. I have tried several from a cheap e-bay to HD all "power" antennas and all with the same results regardless of what amp I was running. Use the stock location antenna and hook a short wire type antenna running it under the fender and up the side of the saddle bag was the answer for me. Now I dont even listen to fm anymore as I use memory sticks and my phone via amazon prime or other streaming service.
