8 inch subs in bags
8 inch subs in bags
Fellas I'm looking at adding a set of 8 inch subs to my stock bags. I use my bags quite a bit and I'm not gonna buy a tour pack. That being said how much room is left in the bags ( can I see a pics). Or I'm I better off keeping my oem bags and buying a cheap set of advanblack and making them my subwoofer bags w quick disconnect to swap out bags super fast. If I'm doing that should I just go to two tens w a 1200x4 bridged or put a 800 I'm each bag. What's the typical setup?
There won't be much room after sealing the bags for subs. Maybe enough for a couple tshirts/jacket. If you want subs invest in a good set of fiberglass bags and reinforce them further and add some dowels. You may be better off with 10" midbass mounted in the rear of the bags if you need the room. Some of them can play pretty damn low.
This is a little 6 speaker setup I just finished with midbass 10's:
Thatdude596 (05-01-2021)
Originally Posted by Thatdude596
I appreciate the honest reasons. So are you saying say no to 8 mod bass drivers in the bags? I will end up getting a new set of bags just for the subs so I think 10 makes sense
Someone can try and talk engineering and speaker cone area and all of that jazz but the ears don't lie. I seriously doubt that there will be more than a couple folks that have had their ears on a couple of parking lot wonders that will disagree.
The 10 in each bag is the way to go if properly set up via fabrication and speaker selection for the airspace to include the most efficient use of watts being spent.
T
