Need help plz
03-12-2021, 01:19 PM
Need help plz
I need a little help. I’m having bad motor hum in my system when motor is running. All grounds Are ran to battery.
03-12-2021, 01:22 PM
03-12-2021, 01:23 PM
Quote:
Originally Posted by
SBates08
DSP in play?
yes Dayton 408
03-12-2021, 01:26 PM
You may benefit from a ground loop isolator. I'll be putting one on mine this wknd as well.
03-12-2021, 01:29 PM
Also double check that amp gains aren't set too high.
03-12-2021, 01:30 PM
SBates08
Gains are set about 11 o’clock on Sound digital amps
03-12-2021, 01:34 PM
Could it possibly be cheap RCA’s
03-12-2021, 01:37 PM
Quote:
Possibly, buts it's likely the Dayton.
03-13-2021, 10:00 AM
I had the same problem. I tried everyhing and realized it was my NVX amp. If the amp body touched metal it would make a ton of noise. If I isolated it the noise would go away.
03-19-2021, 10:29 AM
Update I found the buzz/ ground loop and it’s the fog lights. When I cut them off it goes away. But when I run a ground from the lights to the battery negative it still the same. So I’m guessing bad fog lights?
