Next step lowers - speakers for my combo
Old 09-21-2020, 08:16 AM
northcoastmopar's Avatar
northcoastmopar
northcoastmopar is offline
Default Next step lowers - speakers for my combo
Greetings -
Currently I'm running a fairing only set-up on my '17 Street Glide.
I have as Sony AX5000 HU and a Stinger SPX700X4 amp that is bridged driving a set of Arc Moto 602 speakers. I like the system, it gets loud and has good sound, but like others I want even more volume especially at cruising speeds.
I'm guess my next step is to get lower fairings and a set of 6.5" speakers. I have a NVX VADM4 amp on the way that I can use bridged to drive the lowers. At this point, I have no plans to put any speakers in the bags. I don't want to give up the space so I'm not looking at future expansion.
My music is primarily rock, alternative, blues.
I've seen PRV, DB Moto, and Mmats referenced often as good lower speakers. Which ones would play nice with my Arc Motos? If it makes sense I could drive the uppers with the NVX and the lowers with the Stinger bridged at 350 watts for volume.
Thanks in advance!
Knucklebuster27 (09-21-2020)
Old 09-21-2020, 01:34 PM
Juice's Avatar
Juice
Juice is offline
A speaker not mentioned much but, it makes a great 6.5 lowers speaker. Faital 6FE200.
Great speaker for that location. It will require a DSP to bandpass it in it's wheel house.
Juice
The following 2 users liked this post by Juice:
Bluesman280 (09-23-2020), teedoff65 (09-21-2020)
Old 09-21-2020, 01:49 PM
teedoff65's Avatar
teedoff65
teedoff65 is offline
Received 1,527 Likes on 1,090 Posts
Juice
Agreed, And they're cheap and sound good.
Old 09-21-2020, 06:29 PM
hamah's Avatar
hamah
hamah is offline
I've got Hertz SV 165.1's in my lowers. They sound great to my ears with plenty of SPL (at higher levels they actually tend to overpower my upper fairing speakers). I'd seen them discussed on a few other threads for use in lowers and thought I'd go that route and I'm happy with the result.
Old 09-21-2020, 06:57 PM
northcoastmopar
I like the price on the Faital speakers, I don't have a DSP so the price on those would help me swing a DSP. Any reason not to get a Dayton 408?
The Hertz look like they take more power so could feed them with the Stinger amp and run the Arc Motos with the NVX at 200 per side?
Old 09-21-2020, 08:03 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
Those Faitals will take 250 watts with no problem.
Old 09-22-2020, 09:36 AM
northcoastmopar
Dumb question...4 ohm or 8 ohm on the Faitals?
Old 09-22-2020, 09:40 AM
Juice's Avatar
Juice
Juice is offline
What amp?
Juice
Old 09-22-2020, 10:07 AM
northcoastmopar
What amp?
Juice
NVX VADM4 bridged. 200 x 2 at 4 ohms
Old 09-22-2020, 10:18 AM
Juice's Avatar
Juice
Juice is offline
If you are using that amp go with the 4 ohm and run each speaker bridged. Those amps get warm though!
Juice
Quick Reply: Next step lowers - speakers for my combo
