Amp upgrade assistance!
Upgrading assistance needed. Came across a free Rock DSR1, I just need to order a replacement harness. What’s a good amp to replace the soundstream PN4.1000D? It’s currently running MMATS PA601s in the lowers, and the PRV 6MR500CF’s in the fairing. I plan on moving the soundstream to the rear bags to replace my JL JX400D(located in the rear bag). The soundstream will power my DDVO W8s and PRV TW450 tweeters.
15 SG
HU: Sony XAV-AX100
Thanks in advance!
Brian
15 SG
HU: Sony XAV-AX100
Thanks in advance!
Brian
How does the front sound now? The reason I ask is those tweeters in the rear won’t handle the power from that amp unless you dial it back a ton. You have any tweeters with the prv’s in the fairing? Are your lowers the 601cx coax or just the 601 woofers? If the mmats are the 601coax, I would move them to the fairing and run the prv’s in the lowers. Now that you have a dsp then a sd800.4 evox will do you justice both front and rear. That sound stream will only fit against the back or front wall of your bags and be hard to get to the adjustments while in the bag. You might just want to keep it up front since it is already in there. Just a thought.
Thanks for the info guys!
I currently do not have any tweeters installed, but I plan on putting the PRV tweeters in the fairing. I do not have the 601cx coaxial but the 601 mid-bass drivers/woofers. I know the evox is a great amp from reading different threads. It might be possible that I could get my hand on a db Euphoria amp for a little of nothing, but I don't know anything about that brand.
Thanks,
Brian
Thanks,
Brian
nickrat (04-13-2024)
Thanks,
Brian
Thanks,
Brian
man if you want a crash course in dsp tuning one of the best in the business is doing one last online webinar before he completely retires this Wednesday. If your interested look up Alex haze on fb. Money well spent!
