Two usb connections stock HU
Old 08-15-2020, 12:21 AM
teedoff65's Avatar
teedoff65
teedoff65 is offline
Received 1,527 Likes on 1,090 Posts
Default Two usb connections stock HU
Is there a good clean way to add another usb to my 2020 stock HU? I keep my phone plugged in now for android auto, but would like the option of keeping a larger thumb drive connected as well for my music library. I dont think the HU has a spare usb input, but just checking to be sure. The only other option I can think would be a usb hub, but those are usually larger enough to take up most of the cubby space. Any ideas?
Old 08-15-2020, 04:35 AM
jester0618's Avatar
jester0618
jester0618 is offline
Old 08-15-2020, 07:02 AM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Received 9,593 Likes on 3,245 Posts
My only question would be, how would the head unit determine what input to use when? I could see it if one of the USB was for charging only, but both would be used as inputs. I would imagine conflicts taking place if not switched between a or b.
Old 08-15-2020, 07:29 AM
luigit's Avatar
luigit
luigit is offline
just an FYI i tried using a variety of USB hubs and the harley system never recognized it. i see no way to expand the usb connectivity of the harley system.
Old 08-15-2020, 10:04 AM
mikes300's Avatar
mikes300
mikes300 is offline
i have like 2500 songs stored on my phone, organized in playlists, no need for a thumb drive, can you do that?
Old 08-15-2020, 02:55 PM
teedoff65's Avatar
teedoff65
User to, some hubs has switches. Guess I'm good, was more curious of this had been done.
Old 08-16-2020, 05:13 PM
14cvoultra's Avatar
14cvoultra
14cvoultra is offline
I use 2 different types of hubs one on my14 and a 5 port on my 19 they both work fine on the 5 port I use 3 ports all the time 1phone 2 music stick 3 route stick no issues and they are just cheap hubs. I use a 3 port on the 14 all 3 all the time 1map 2 music 3 home made voice command system on the 4.3
Old 08-17-2020, 04:40 PM
mag11581's Avatar
mag11581
mag11581 is offline
i got a usb splitter from amazon. plug my thumb drive and android phone in at the same time.
Old 08-18-2020, 08:33 AM
14cvoultra's Avatar
14cvoultra
just name the usb stick to what u want and you will be able to choose the one to play
Old 08-18-2020, 08:35 AM
14cvoultra's Avatar
14cvoultra
this is the one that I use on my 19RGU you can turn the ones off that you are not using.
Amazon Amazon
Quick Reply: Two usb connections stock HU
