Biketronic's 4180, and 4 Mmatt speakers!
So, it's ordered, how is install? I have a pair of Stinger RCA's is all, (for the line levelers to amp) I'll be doing stock HU as mentioned above, Dayton 408, and two pair of speakers. Do I need more RCA cables or what? Does someone have any instructions or layout of how it hooks up please? Got a call into the place I ordered it from. No call back all day, that's frustrating...
DSP
Black = Ground
Yellow = Pos
Red = remote turn in from sled acc
Blue = remote out which should connect to amps and their remote turn in.
T
Thanks Tailwind, how you been sir? So, with my stock HU, and BT Amp, will I need anything else to install this? Can you "Dumb" that down a little? What is PAC SNI? (Or is that simply my DSP in another brand?)
SAWEET! Just went out to my garage to see what I had before BT offered the Line Levelers. That's exactly what they first gave us to run their amp. In my shop drawer I have two PAC SNI 35's. ONE with an HD plug on it. The other with wires out. If there are any printed instructions available. OR even a sketched lay out of how things are hooked up I'd really appreciate it. Sorry for all the bother, but really appreciate the help!
So it looks like I'll need to order another 18" Stinger RCA cable,, only have from the Line Levelers to amp right now.
The PAC SNI-35(LOC) is a Line Out Converter that changes high level input to low level input (rca). You will need a total of 3 RCA's. One for input from the LOC to the DSP(inputs 1&2). One for output 1&2 on DSP to the front channels of the amp and one on output 3&4 on DSP to rear channels of the amp.
So it looks like I'll need to order another 18" Stinger RCA cable,, only have from the Line Levelers to amp right now. But I have two PAC SNI 35s,, I only need one? I'm more and more confused the more I understand, LOL....
well I thought I had it understood till you said three RCA. If I understand correctly. I’ll have two PAC? Which would theoretically give me a place for two more RCA’s. If I only need one SNI then how is that hooked up for two pair of speakers. Sorry for the frustration I’m causing. Hell I feel like a idiot not understanding easily. I’m Avionics’s and worked on the Phantom, F15’s and the B2 Stealth Bomber.
