Mic with Sony 7000 & CarPlay?
As I understand it, I can’t use CarPlay and a bluetooth headset/mic paired with the phone with my Sony 7000. So, has anyone had any luck with a mounted wired mic, either the one that comes with the HU or another one? I’m not holding my breath, but it sure would be cool. to have a noise cancelling mic and be able to use voice commands with CarPlay. Got a little spoiled with the GTS and WHIM I guess.
Maybe I was misinformed. I hadn’t actually tried it because I was told that it wouldn’t work before I even bought the Sony.
Im going to try it a little later.
Are you saying that with your phone plugged into the USB1 of your Sony, with CarPlay engaged and music playing from your phone through your Sony and motorcycle audio you can use voice commands through the headset to make/receive calls, tell Siri to get you directions that then show on the Sony screen, send voice texts, etc.?
@BrandonSmith - I must be doing something wrong.
thats why I don’t understand why people spend a fortune on WHIM and HD SENA headsets with their stock head units. Just use your Bluetooth headset to control the phone, rather than spending $1000 to control the radio.
yes, why would that not work? It’s the same as being in a car with a built in mic, or using any other headset with the phone walking down the street.
I played with my HD branded Sena 20s this afternoon and couldn’t get the Bluetooth to control the phone while CarPlay was engaged. Engaging the headset moved the music playing to the Bluetooth headset speakers and I couldn’t engage Siri on the phone through the headset to tell her to get directions or call or text anyone. The calling features appeared to only be those available through the Sena to call preset people, for example.
I use it just fine as I described. Hell I was even my car with CarPlay going, turned on my Bluetooth earpiece and controlled Siri with that headset just as I would through the car or my sena helmet headset. I’ve had the same issues you described in the past, and you have to start the bike first, get CarPlay connected and once that’s all booted up, turn your headset on. Once that’s paired, it should work fine. But once you shut the bike off and turn the bike back in, you’ll have to turn your headset off and start all over again because CarPlay will want to ignore your headset again.
What I did to get around all that BS is to pair my Sena headset in “phone selective pairing” mode - which won’t allow music to play through the headset. By doing that, I’ve never had one issue. All the issues you described went away. It works flawlessly.
In short, do the following and hopefully your problems disappear:
Thank you!
