Hot Garbage No More - I hope
For those of you that have been following my system changes and learning process over the last few months, the title is a reference to @haze324’s description of my last setup.
As I’ve learned and experimented I’ve arrived at the latest setup. Used a multimeter and ohms law calculator with a 1Khz 0db test tone to set gains, and a DD1 to make sure I was not distorting at the head unit or out of the amps.
Sony 7000 Head Unit
DSR1 (Bought a DSI2 and set everything up with that the first go round, but sadly I couldn’t fit the outer fairing back on with it.)
SD1200.4-2 EvoX bridged to two sets of Ground Zero Yellow Baskets in the Saddlebags (2 in each bag). 300W each. Crossovers at Band Pass: 65hz - 300hz: 12dB slope
SD1200.4-2 EvoX bridged to four Hertz SV 165s in upper and lower fairing. 300W each (but dialed back a little on the DSR1). Crossovers at Band Pass: 100hz - 6K: 12dB slope
SD400.4 EvoX running one set of Diamond Audio MO75T horns mounted in my grills. 50W each. Crossovers at Band Pass: 6K - 10K: 12dB slope
All amps and DSR1 mounted in the fairing using a XEL rack by Lex Rivera
As always, open to feedback, but I’m pretty excited to run this setup.
Sony 7000 Head Unit
DanHappy (05-19-2020)
Sony 7000 Head Unit
Sony 7000 Head Unit
following this thread for the expert critiques which are so valuable.
I thought that you’d be a little proud of me for a combination of components that has better potential and plays nicely together... no?
What other tips do you have for maximizing the setup?
Time to move on to another hobby.
Dorian's a good dude.
Dorian has a great reputation and I’m sure that he will get all there is to have out of my setup as soon as I can get in for him to tune it. In the meantime, I’m open to any tips/suggestions you have for how to get as much as possible from the system. Having tuned a ton of bikes I’m sure that you have ideas on crossover, eq or even gain settings that I can play with until Dorian has an opening.
Bluesman280 (05-19-2020)
