DIY Sony HU Water Protection
I decided to get creative and protect my Sony 7000 HU from potential wet conditions, so I thought I'd share what I've done. I watched a Biketronics video and saw how their $500 enclosure is plastic sheeting taped to the radio, so I figured WTH I'll give it a go with heavy foil. I made sure to tape very similarly to BT as well, to protect any openings from moisture intrusion. I know my way is not as protected as BT's radio wrap, however, I'm completely comfortable with my radio's protection now and feel my method allows the radio to radiate heat rather than insulating the heat. I am also fully confident in the leaving the screen uncovered.
Supplies: uninsulated HVAC duct foil, duct/sealing/foil tape (any tape that will resist moisture and heat). This stuff is metal (heavy gauge aluminum foil), so it doesn't let moisture through, it fits snug, and it will [hopefully] help dissipate heat (which is why uninsulated foil is important).
I don’t know exactly what I have as it was leftover from an old neighbor’s shop building. I would think any industrial aluminum foil would work. Grainger sells it but you’ll end up getting 500 ft for $50. https://www.grainger.com/mobile/prod...ebparentimage$
This is what I used, with the insulation removed: https://www.homedepot.com/p/Master-F...RP60/100152008. Not any cheaper.
Help
Let me see if I can cut/peel away the outer foil from a run of flex duct I have in the attic. I ran a new duct last year into the master bedroom and have a long run left. If so I will take a picture of it and can just give you some enough for covering the HU. Not known if that will be today or tomorrow. But if it works out, again free. Both of you have helped me in the past.
I am sure this would work just fine. It is vynal and should keep water out and be easy to work with.
https://www.homedepot.com/b/Kitchen-...B&gclsrc=aw.ds
