Anybody try the TX48 with the DB G2's or Mmats coax?
Currently running the Mmats 601.4cx in the fairing and the DB Moto G2's in the lowers off the early Stinger that were only 100 watts.
i have a Massive TX48 kicking around and am thinking of trying it out on the Mmats and G2's.
How much power would a guy be good to feed those Mmats? Currently only feeding them 100 watts.
How much would you feed the DB G2's in the lowers?
They should be able to handle more than the Mmats which should work out well for balancing out the front stage.
My front stage sounds good and is fairly balanced, but would like to put a bit more power to the G2's at least.
Lets start with the type of music that you listen to.
A 6.5'' is only going to produce so much output(bass especially)
I think most folks are asking too much out of a 6.5'' full range speaker.
If you listen to mostly rock and roll you probably will be ok with running them full range.
If you lean towards more dynamic music, pop, edm, techno, hip hop. You do not want to run them full range.
The TX48 is a powerful amp and if setup correctly will serve you well.
Start off with the gains at half and the crossover at full range.
As you increase the volume on the radio you can raise the gains and if needed add the crossover to the desired level before the speaker distorts.
Play tons of different tracks from different sources to know your threshold.
Do that with each set. Your gains will probably be lower on the G2's as they are wayyy more efficient.
It should blow you away.
Let me know how it turns out.
Bluesman280 (04-21-2020)
I have the current settings dialed in fairly good with the Stinger, but I'm also using every ounce of it. I've got the x-over dialed in to give me some nice punch with both the Mmats and DB G2s
I've used the DD 1 to maximize clean output on the Stinger, but I find when I'm rolling down the highway at 80 mph I am running my system right on the threshold of it's capability with the Stinger. My Stinger is one of the earlier ones that only puts out 100 watts x 4.
Can't squeeze any more out of the Stinger, but figured I might be able to squeeze a little more out of the Mmats if I fed them a little more power. The G2's work great in the lowers with the Mmats. Even with the higher efficiency of the G2'S I've currently got the gains right around the same as the Mmats and the G2's could still use just a tad more volume. The G2's are louder in the parking lot, but are just a tad shy of balanced at 70 mph plus.
Figure I should be able to dial in the gains to get the full potential out of the Mmats with the TX 48, and have plenty of power to bring the gains on the G2's up to the perfect balance from the lowers.
Dayton DSP will be going in with the TX48 for tuning purposes. Also trying to squeeze the Stinger under the fairing as well to bridge to my speaker lids.
Once we get the front stage sorted, then I'm back to the drawing board on the Speaker lids, because they are already having trouble keeping up.
I think we have a decent plan to optimize the front stage with the gear I already have on hand.
Figure I'm probably good all the way up to 175 watts on the G2's.
Just not sure where my limits might be with those Mmats 601.4cx. I see they are rated for 100 Rms and 150 program.
I know I could get fairly aggressive with the G2's but I was being a bit conservative with the Mmats because I couldn't hear them well enough on the highway to know if they were struggling in the lowers.
I've been running them in the fairing with the Stinger the last couple days and they have been sounding great. Looking forward to installing the TX48, hopefully it doesn't lead to any magic smoke.
Biggest challenge now is trying to find some speaker lids that can do the front stage justice. The JL 8.8" sound good in the parking lot off the Stinger bridged, but they get lost pretty easy once the bike is rolling.
When I first got to tinkering with lid speakers they got lost in the wind as well. Adjusting the fader towards the rear helped a little bit, but in the end more power was what was needed. I don't know how much power your 8.8s can handle, but I'm sure others can advise.
Now that I am feeding it properly my rear stage can keep up with the front no matter what the speed.
