matching gains to lower wattage speaker
Here is probably an over thought dumb question but,I have a amp bridged at 500 watt x 2 channels and will be running a speaker on each channel rated at 250 rms, and 500 program power,
do i match gains at 31.65 volts to rms power? 250watts)
or 44.5 volts program power ? 500 watts)
T
Bluesman280 (04-05-2020)
If so, Tailwind is spot on with 1.5 - 1.8x RMS (approx 375w) or 38.7 VAC
no its just for some prv6x9 s in the bag lids, temporary for now ti l i get 8" lids for some reason there crossed at 1khz so i will probably remove the passive xover and use the amp xover at 100, so i will have to turn them down anyway. money has become a roadblock with the current events.
i just wasnt sure about the term" program power" ,they didnt have that term back in the day
yes 10s are the next step, the amp for the 10s is already installed and waiting,
I got these for a good price used to hold me til paychecks start coming again.
and because these are 6x9 lids.
I think I have decided to replace them with 8" lids anyway, the sealed 6s or comp drvrs seemed like a great idea, but I knew I would want 8s eventually anyway and the sealed and comps are only available in 8 ohm... my goal is to set up on all 4 ohm, w/10 channels so a dsp can be most effective?...
I did get them installed tonight and they actually have a surprising amount of mid-bass/mid-range and excellent vocals,
They will be for sale, with the lids in a few weeks,.or get moved to another vehicle once the paychecks start coming again.
