Wondering about power wire gauge for these 800.4. I read it needs 4 or 6. Issue i have using even 6gauge is the positive and ground on the are very small inputs physically...and they are right next to each other. So the 6 gauge wire is way big for it. It seems to be built for 8 gauge
any input? I'll be runningrall 4 channels 2 6.5 and 2 6x9
The ferrules will work if you use the screw to tighten them down, I just tried to use the ferrules and crimp them with the square crimp tool and the 8 gauge square did not fit!
I ran 6 ga before I realized no way was that going to work right connecting to the amp. Now that the bike is all back together I plan to connect 8ga to that 6 to connect to the amp...ugg
Juice
I can see that. The 8 awg ferrule needs to be un-distorted to fit in the amp. The screw makes a nice indention in the ferrule when tightened down. I also put a small dab of blue Locktite on the set screw.
