Looking to build kit on SD 1200.4S EVO....
New 2019 FLHTK and looking for a slight upgrade from the traditional Stinger/mmats kit. After quite a bit of research I picked up a SD 1200.4S EVO (4 ohm) as the the basis for my kit and hoping to leverage the expertise here to help me build the rest. Have about $1,000 left in my budget to complete the install. Here are my questions....
- fairing speakers?
- lower speakers?: Picking up Hogtunes adaptors for LC Lowers. these have roughly 2.5" depth. Had them on previous 2017 FLHTK and decent quality product.
- Not too concerned about tourpak:. It's detachable and throw it on for long tours and passengers. Simply looking for the 4 speakers to run off the front L/R channels.
- DSP versus BT LL?: have tried both...a low end DSP (<$100) and BT LL on previous FLHTK. I found that LLs really reduced the volume. My research is pointing me to AA PSM DSP which seems a little pricey but would extend the budget if necessary.
- Amp tray: Seen another thread recommending J&M tray for this amp. Pricing comes in at $160 for stamped SS sheet metal. Am i missing something or is there an lower cost alternative?
You are defiantly going to need the JL amp tray
I would recommend the DSP route over the LL as you will get to control the sound quality to each speaker vs a "can sound" that the LL will give you
Last with the speakers it really comes down to what you are hoping to achieve in sound quality and what you're willing to spend, clearly the better sound will come from better speakers, which may also require a separate set of tweeters and a separate amp to power them in the fairing
You have invested a lot in your amp, you will want speakers that work well with that amp - otherwise it's like putting a big block engine under your hood and not matching your wheels/tires to get the power to the ground & you will be left disappointed
Thanks Chopper! They ship to Canada which is a bonus. The US$40 savings converts to CAD$58. Much appreciated.
- Arc Audio Moto602-HD
- WDX6MOTO-G2
- HERTZ HCX 165
- Alpine R-S65.2
