Line Output Converter Question
Right now I'm running he stock head unit with the BT355's. When the weather breaks I plan on getting the 4/0 flash or the RF flash. If I go with the RF flash what LOC's do I get where I won't have to cut wires for the input connection? Or scrap both of those options and get a DSP? Either way I don't wnt to cut the factory speaker connections.
U won't have to cut into the factory stuff upstream of a hard wired harness if u simply use the speaker level wires downstream of the front L and R speaker harness just agree the harness leading into the pods. Aka the wires that were inside the pods going to your speakers and connected to the hard wired harness just outside the pods. Hook those to the LOC.
U picking up what I'm laying down?
T
The AHB connectors haven稚 caused me any problems that I know of, but I would definitely like to know if there is something I should be on the lookout for based on your experiences with them. What makes them no bueno?
It's good stuff, not cheap though. E.G. Their $20 harness for the remote turn on can be gotten at HD for $10. And if $10 is too much, there is always the cig lighter that u can tap into for free. Lots of ways to skin the cat.
T
ReDo (02-26-2020)
$70 for some amp connectors, rca ends, and some wire wound resistors is ridiculous. Maybe $7 in parts there. It's very easy to use components already on hand to make a low level into the amp. The SNI 35 is $8 1 ft rca is $8 so $16 or $70, even less if you don't need the LOC. As I have already said the last time I was flamed for being cheap...I'm cheap. Especially when the extra money adds no sonic value.
They make good stuff but in some cases they are simply not needed or there are very viable other resources available for a very small fraction of the cost.
T
T
I understand that there are less expensive options for some of the stuff I知 doing/using, but since this is my first time not using a fully plug and play system I知 learning as I go. Sometimes that means I知 wasting $ unnecessarily (hopefully I learn those lessons) and sometimes I知 accepting that I知 paying more for the same of convenience. You池e doing right by all involved to point out the options... pay more for X; pay less for Y; pay even less by doing it yourself with Z. I appreciate knowing all of the options and being able to decide. So thanks for putting it out there!
I can understand paying for convenience. I pay the $5 for Kroger pick up without a thought. My concern is people paying that price without knowing the cost. I have strongly considered making harnesses myself. Vtwin's pricing is very reasonable but their location presents difficulties that I think I could do a better job at.
