I could use a second opinion...
Old 02-25-2020, 07:01 PM
Alphadog4312's Avatar
Alphadog4312
Alphadog4312 is offline
Default I could use a second opinion...
I completed the install, not sure about the tune. It sounds good, a little too much on vocals occasionally, just a little here and there.
Example: Long necked ice cold beer by Luke Combs. If I wanted to soften the vocals a touch where could I smooth it out?
Maybe it’s just me. Also still stuck in the garage, may not be an issue outdoors.
Old 02-25-2020, 07:03 PM
Alphadog4312
First photo upload was not good. Hope this helps...
Old 02-25-2020, 08:19 PM
InthewindMN's Avatar
InthewindMN
InthewindMN is offline
What speakers are you working with?
Old 02-25-2020, 08:33 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Hoyt 1911A1 is offline
For my speakers I think the vocals were around 3000 Hz.
Old 02-25-2020, 08:36 PM
IArider1's Avatar
IArider1
IArider1 is offline
I use this as a reference
Old 02-25-2020, 08:43 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Luke is damn good and has big MALE vocal presence. Some of these make vocals can be found in the 90-190 range and some also hang out in the 300-350 range. Tinker in those general areas a couple DB and see what u can find.
T
Old 02-25-2020, 08:55 PM
Alphadog4312
Beyma sql60 fairing mirror spot off sd 250.2, 7.1 HAT’s fairing, Beyma 6nd lowers off Biketronics 4.250, GZCX 10’s bags no port bridged off NVX 1000.4, Hertz ST 25 bags of their own sd 250.2.
Old 02-25-2020, 08:56 PM
Alphadog4312
Thanks rider, that helps.
Old 02-25-2020, 08:57 PM
Alphadog4312
T
Thanks for the advice.
Old 02-25-2020, 09:02 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 31,028 Likes on 11,644 Posts
Second opinion...you’re ugly too.
Quick Reply: I could use a second opinion...
