Amp size and mounting help
As for the mounting. I usually just Velcro the amp to the tip of the HU, and that has seemed to work pretty good. Make sure you use good quality Velcro. I have a roll of industrial Velcro that seems to work pretty good.
Do you have an amp in mind that you are trying to fit in your fairing? Someone might know if it will fit.
I don't know the measurements off hand, others might be able to chime in.
There is quite a wide range size of quailty sounding amps the will fit on the stock amp tray. The max footprint I have used is the JL XD400/4 which is 8.5x7x2. You also have to take into consideration of were the wire terminals are.
WhereduGo?
2014-2023 Touring Models
12-02-2016 06:41 AM
